Disables BFD client services for IPv4 static routes.
| ip_addr | Specifies the IPv4 address of a neighbor for which BFD services are to be stopped. |
| vrname | Specifies the VR or VRF name for which BFD services are being disabled. |
Disabled.
When the BFD client is disabled, BFD services for all static IP routes terminates. This command does not disable services for other BFD clients (such as the MPLS BFD client).
The following example disables BFD client protection for communications with neighbor 10.10.10.1:
# disable iproute bfd 10.10.10.1
This command was first available in ExtremeXOS 12.5.3.
